kunce when can you make it?
What did we go with last time? 7?
Train arrives at Southbank at 6:30
If we get there at 1830 we can at least get a table and shiz, and one of us can run down to Buranda/Southbank to grab Colin
This works.
Or we could make the dirty pom catch a bus :)
On that note: Lift?
I might pull out, not sure yet
That's what she said.
So we doing this or not?
German club for dinner then Miso's place for game?
I still think he should walk in with his 50" tv under his arm. He'd make it look like a iPad and get away with it.
In-som-nia
Sucks to be you! Nice LEDs though.
Morning Mangs.
So whats the plan?
Rape, pillage, loot, eat some eggs, loot some more, work, pillage, pillage, origin
Something about a barrel o' rum in there too
Sarp mangs.
Sarp
Sarp.
Sarp
JOHN - you added my friend Katy on fb? Hahahahahahahaahahahahahaha how quaint, she's like, 15
Edited by mosquitocoils
Keen.
Keen.
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
