morning ya'll.
support qld.
already thought of having some people over at mine for the game, but the other half has to be up at 6am the next morning, so she's not quite that keen on having visitors.
i might have to can any plans for the evening, and instead organize something for the next one?
heading out to work now, so won't get any updates till 5:30pm this arvo.
That's why you lost, you can't play cricket while on top of a ladder. :P
Ah, that must be it. We're doing it wrong!
That's an addition that would improve cricket 9001%
F*ck you, dirty pom.
But still, 9001% of 'shit' is still shitx9001
F*ck you, dirty fake injun.
Sheesh, you guys are meant to love cricket. You're almost as good at it as Australia :P
morning ya'll.
support qld.
German Club?
Ladder's in cricket? un astrayen ?
Definetly unastrayen
Yeah but...it's over 9000!
morning ya'll.
support qld.
must have updates by 4:30pm other wise I'll miss the 5:30 train negros. Or I just stay home n catch up on some sleep.
German Club?
Cricket sucks :P
Calling some one unastrayen is unastrayen. Your unastrayen...
<3
<3
awwww
wubs
:P
so whats going on ? we german clubbing? do you need to bring your own club ? or are we ladder cricketing ?? could be the first annual game
awwww
wubs
:P
<3
I'm still keen for german club...
Edited by Smity42
OK Miso is out for german club. He's not keen to head anywhere else instead. But he is going to hit up the better half to see if we can go to his place and get back to me.
Otherwise we could just go without him?
Any other options?
Any other options?
ladder cricket ?
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
