Pizza capers pwns Hells, its not even close IMO
+1
Hell Pizza is crap. And so is that Earth & Sea bollocks
Capers > Hells AINEC
They are different style of pizza. Hell is the best of the fatty 'fast food' style pizza, which I happen to like (as previously mentioned, I lived on it for 6 years :down:). Capers is a bit more 'gormet'. I refuse to rate one above the other, I like them both.
I remove the thumbs down as they are good pizza's
Good.
Then there's no debate at all. Pizza Capers FTW.
;) but still going to hell's pizza tonight as it's practically a drive through on way home.
Damn you. No practical Hell for me ;)
Hotties + Pizza? New destination for thursday night meets?
While good, they do not even come close to comparing to the JB buffet on offer at baskins
Sarp Mangs. Hot new graduate started today. It's awesome.
Nice. I feel we are overdue for a new hot admin trainee here actually...
picsormuthafarkinban
+1
ill see what i can do
do or do not, there is no try
I've just started my engineering course... If thats anything.
techincally I would call that something, in the same sense a bush that I drive past is also techincally something.
it's not really of interest to me, but it's something..... it's there
Give me some good music to download, mangs.
John, these are the highlight albums in my recent playlist, not sure if there's anything in there for you but at least I tried
Death cab - narrow stairs (wishy washy ambient "emo" but great)
Death cab - plans (better than above, very introspective)
Every time I die - the big dirty (screamo/metalcore)
Steve aoki - pillowface and his airplane chronicles (dirty electro/house)
Bury your dead - beauty and the breakdown (metalcore)
I get my gauges mounted up on friday
I'll mount you up
Thanks man. I'll check out the ones that aren't electrofaggotry
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
