Looks like a few newbies. shame I miss out
yet again
Nice work above and beyond thanks GaraGe31.
What are you doing in here Rangamister? Aren't you s'creaming it up ?
Martin: I left a message for the guy with the crashed GTV. I'll let you know if he gets back to me.
Tristan: Can you please have a look and see if you still have the rear speed sensor from your 32?
yeah, had planned to get out there, but ended up having a few too many drinks to drive there
instead sat on my couch and played modnation racers. whoooo :)
So i get into the office, fook all works. Server is missing. Turns out its been changed, upgraded - Who knows. When? Should be done around miday.
me - so we're all doing what until then?
Office - Well the net still works...
ROFL
I REALLY want to post this on the lowballer forum:
I'm teaching a young girl how to drive and she just can't get the hang of putting clutch in before changing gears.
It's just nature's way of telling her she should get back in the kitchen
:blush:
But I have my mod hat on and not sure if I should...
Edited by Smity42
same hey
I'm researching brake options for project alfa. I don't think the 32 brakes will work :blush:
Why is it a no go?
lol. You're a mod over there?
Why is it a no go?
Too small for the front (sounds crazy I know, but if I'm going to customise the brake setup I'm not going to do it half a*sed), too big for the rear.
Theres some 4 piston 330mm alfa brembos on ebay I'm keen on.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :blush:
I give it about 10 mins tops till I think "f*ck it" and post it anyway.
Jawol. Sucks being a mod, I'd have posted it in an instant if I wasn't :(
Yeah needs more 355mm rotors and big 6 pots. :blush:
Link to thread and I'll post it lol
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
