That would be cool. Next time I have her I'll let you know. You can come and have a look around anytime but it has to be either on a afternoon 3-11 or a late 11-7.
We should do it on an 11-7 Thursday :sick:
I'll see if I can steal Jack next time you've got her :action-smiley-069:
17th of june ?
as long as you wear a ninja mask when you do it and run away with him under one arm :)
No car... but if anything probably the cheapest thing I can get :sick:
t-shirt ninjas ftw... but not t-shirt ninja pedobear O.o
Martin would like it here... I'm staying at a university college and its full of not-quite JB. :action-smiley-069:
correction: they've just finished exams, so make that very drunk not-quite JB.
Edited by GTTG
irection!!
Will Geoff deliver ? :sick:
Will Jason fall asleep at work ?
Will John get his Ninja shirt ?
Will Tim enjoy his breakfast and will Colin ever be able to go near a 20 watt bulb without getting 3rd degree burns?
Stay tuned...
see this is why we need msn... you don't say that kind of stuff there. You just ask me to turn on my cam :action-smiley-069:
Yeah but that's different. We wear wizard hats and robes when we msn. In here I go pantless.
Doesn't have the same feel. :sick:
I'm calling it a day, so I bid you good evening, gentlemen.
Nothing stopping you both breaking out those wizards hats after all.... maybe even the cookie-wands?
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
