has potential then
So remember it when the zombies hit the fan.
Speaking of hitting the fan have you seen that zombie flick where the hero straps a lawnmower to his chest and walks through a mass of them? It's pretty awesome.
evenin' gents
Whats the consensus on zombies and razor/barb-wire?
Also; seen this before?
http://www.urbandead.com/
Doesn't it tangle them up for a bit ?
Signed up :thumbsup:
Forgots to tell you John there are three of these control rooms. This one here, the one in the valley and one in the centre of brisbane. All have generator backups and secure doors. The one in the valley doesn't have windows on the door and is three floors up.
I'm still unsure of those plastic hats though... I think they'll cause more harm than good.
The one you're at is probably the safest, there's less population out there, and the roads are much more open.
we could throw them at the zombies and then use the rifles to shoot at them like ducks at a side show.... *bang* *ting* zombie turns and repeat. :thumbsup: Could be fun for hours.
The glass also worries me slightly... But I guess it's hardcore soundproof double paned thick shit huh?
Not sound proof. Its the non shatter stuff though with metal in it.
Joined... think I'm already dead though. Was a bit over eager using up my action points ... eep
You and me both :thumbsup: Can we join forces and f_ck shit up ?
Well... I don't have any points... so it probably wouldn't let me join my own dick with my hand at the moment... let alone join forces with someone
Well you could always try the dick to hand move. I've heard its quite effective.
i guess so!
ah beer. isn't it amazing you can't just have one. like a coffee or a can of coke you have one and think thats enough for me. Beer you think i'll just have another one and another etc.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
    • There's another sensor that sits inside the evaporator, that's a C U N T to get to, but can be done without removing the entire unit. Usually it's not the sensor that dies but the actual capacitor in the circuit (part of the plug that dies).
    • Putting the climate control CU into diagnostic mode is independent of the ECU. You just have to do the dance prescribed in the manual. No, I do not know what the dance is. I have an R32, so use the dance in the R32 manual. On older cars, I would have said "no, the ECU should not affect whether the A/C works".... but for an R34 that might be wrong. I don't recall the detail, but there was extra mods required to make my R32 A/C work against the R34 ECU. The R34 ECU apparently gets involved in the running of the A/C more than earlier cars did. Theoretically, if the PFC is a true plug in, then it should just work the way that the original ECU does - wrt A/C. But there's always scope for them to have not cared. Nope. Pressure switch out = getting the fridgey out to pump the gas out before pulling the switch. The switch really cannot sense gas pressure unless it is up against the gas.
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
