as requested:
Desk is shared between 2 of us, red line indicates approximate position 'my' desk ends
that fkn blows! good thing you dont have any work to put on it :D
damn, were are you to put you footlong sub on that?
man my workbench you could have a party on. Actually come to think about it you could, 2.5mm thick stainless steel is hella strong my hammer can't dint it
Works in service..
11pm - 6am kind of job
I wouldn't need a desk for that :)
Miso, my qualification is in Computer Systems Engineering (Read: Software Engineering). My current role is hard to describe, basically I do semi-HK IT stuff (ie not "Have you tried turning it off and on again" ) :D
Bring it to the German club
German Club when?
See you later Jason, have fun in Auschwitz
It's not such a bad place :)
Nice desk by the way :D You should put up some police line do not cross tape where the red line is :3some:
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
