ummmmm it was beautiful
however i over ordered heaps
worst part of going to get food when hungry
got a spare burger for afternoon tea now...
now just waiting for a movie to start i wanted to watch and pour a JB and coke... :)
When I over order I just keep eating until I can't move and it hurts to breathe. Make sure you put a long movie on first though!
Evening all
The laser's compression test results are as follows:
1 - 160psi
2 - 5psi
3 - 5psi
4 - 160psi
Die
Evening all
1 - 160psi
2 - 5psi
3 - 5psi
4 - 160psi
Die
hmmmm... so... step one probably should have been "get engine checked" before "purchase car" ?
Hey any of you guys got a vipec v88 installed on your gtrs?
I just got one installed and i don't think its quite right. For starters, i made 1kw less power apparently then the factory computer.
Now it doesn't idle correctly in my opinion (sometimes almost stalls and then jumps back up, other times just idles fine)
Then when your going from vacum to boost, it kinda hesitates and jerks a bit then all of a sudden lauches away????? WTF is going on with this thing? any ideas
Thanks guys and girls :whistling:
Matt
Sounds like what my car was doing when the coil packs were playing up.
Who installed the Vipec?
I only just installed splitfire packs before i even did the ecm. Also i got a hks twin spark system installed as well at the same time. Wonder if thats whats giving the issue.
I won't say who installed the vipec as i don't wanna slander anyone when i could be something out of there control.
Same people that installed it tuned it.
Yeah its going back to them next monday. They recon it would be fine to drive till then (had it since thursday and already put 300ks on it since. Not by choice)
Thinking it may have something to do with the tune. They were recommended to me by twoogle. But they haven't had much experience with them apparently. But said that they would be able to tune it and make it run like a dream. Now runs like a bag of sh#t and i really hate driving it. You look like a tard when you try to take off cus its got a huge flat spot and almost stalls!!!!!
Edited by 32vspec2gtr
Ha ha yeah i recon!!! Am not impressed to say the least.
Do you get to many meets Isola?
Gotta get around to meeting up with some skyline drivers and that. Just haven't had the car running smooth enough to get to any yet.
:whistling::thumbsup::wacko::no:
When is 40km per hour through a road works not 40 km/h?
When your in a green tarago doing 60km/h in front of me and I get the "Your going to fast wave"
I was doing 40km/h in third but because I looked fast.... grr farkn hulk smash!
Scarnon kuntz ?
:D:rant::rant::rant:
Scarnon kuntz ?
They all stare at me like I'm about to do mad Tokyo Drifts when I drive through there too :P
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
