Fark all brah. School holidays so entertaining the kids. Taking them to the indoor playground thingo today, they fkn love that shit! Milf watch for me.
Sounds like a good day mang. I'm working till like 1 then we've got the work end of year touch football game/drinks/dinner so should be good.
For those that don't read my build thread:
OK, I've had my fun, here 'tis:
And for Colin:
No wait, that isn't right :D.
I only got 1 cat each side, the ones on the headers:
I think it has 5/6/7 cats in total, but the rest are further downstream in the exhaust system.
Unfortunately because the exhaust collects straight into a cat those headers are no good to me, so I guess its going to have to be custom headers (oh no, how sad)
It is the same engine as one of these:
But mine is not out of a GTA so it doesn't get the "GTA 3.2" stamp on the plenum
Also. the pallet had a mysterious white powder on one corner when I picked it up:
Dan tried it, he said it wasn't any good:
ATTN: Anyone who knows about trailers
My dad is out somewhere in the middle of f*cking nowhere, with his sailing boat on a trailer with pissy little 8" wheels on it. Apparantly the wheels have not held up well to the trip out there (and he still has further to go!), so he wants to put bigger wheels on it for the trip back.
He asked me to find out what the options are for him.
So whats the go? Are these wheels likely to be a standard PCD etc so he just needs to find bigger wheels with the same PCD. What would it be?
Or does he need to replace the hubs? Do all trailers have the same stub axles or does he need to find out what his has?
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :D
Edited by Smity42
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :P
Just for clarity, does he have a r33, or an actual boat on the back of the trailer?
if it is an r33, drive it off the trailer and drive it here.
If it is an actual boat, attempt to sail it here?
I accept your many thanks in advance
Martin - there are 4 and 5 stud trailer hubs. Most of the 4 stud are 5.5 INCH PCD which is ummm.. *counts* 140mm (as long as I've woken up enough to work out that math right...)
Any wheel will fit if it has the correct PCD, so he could put 13s on if he can find them. How big is the boat (weight wise) because trailer tyres have load ratings like car ones, so if he can work out what tyre he needs, he'll know what rims he needs. My suggestion would be getting tyres/rims that can handle at least half that weight again to take anything else on board into account (fuel, rods, air tanks, blah blah blah, you get the point).
That's really all I know about boat trailers, and it's been far too long since I've really has much to do with them, but hopefully that's SOME help.
The 5 studs I can't remember the PCD for though, so you'll have to hope he has 4 stud :)
Failing just living on hope you could get your Google on and show up that MUZT3K fuckwit :P
An actual boat.
Thanks for pointing out that lack of clarity in my post, it could have caused much confusion. Although, I wouldn't want to be towing a 33 on anything with 8" wheels!
Re sailing it back - he's going to lake eyre, there is no path of water to sail it back.
The boat is a tiny little sailing boat (monohull), weighs nothing. He has stacked up the trailer with supplies though, good point.
I've been getting my google on (instead of working) but so far I'm just getting more confused, i've found dozens of different 'common' stud patterns, and even a lot of 8" wheels that ARE the hub, ie the wheel attaches directly to the axle on a bearing.
I can't remember if dad's is 4/5 stud or if its a funky bearing one, I'll have to wait till he rings again because it's going straight to voicemail (he has to drive to the top of a hill and plug in his big antenna to get reception, lol NextG is shit)
Thanks for the help broseph
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 🤗
    • Any difference in induction noise?
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
