Im in Sydney both of those dates. :down::)
Well done with those letters, well written so hopefully people will perk up to it.
Write to Today Tonight or ACA about it. That would make for interesting TV.
Yeah why not should be good for shits and giggles.
Which Wed (21st or 28th) ?
That's what he's asking. What will people prefer/go to.
I'll change my preference to next wed (28) because i may still be a bit sick this wed
next wed it is the 28 im in for that
PORN LADY UPDATE
Yep she did lose her job.
THE END
luls that is pretty bad
Mangs *tips hat*
out for gemania in for thursdayia
Mang *waves salmon*
These both look damn sexy on me:
But then again so do these ones:
Nobody had these ones for me to try :D
The incredibly hot chick @ sunglass hut said I should get the plastic ones, but then wouldn't give me her phone number (even when I had them on) so her opinion is no longer relevant.
They are that cheap on eGay I might get one set of the wires and one of the plastics...
sunglasses
I think Straight Jackets look like sunglasses lebs or terrorists should be wearing and they make white guys look like roid munching asswanks.
I'm not a big fan of the new Minutes, I really liked the old ones though. My vote goes for the Square Whiskers still.
I should get new rubber for my Juliets and wear them again.
Hahaha john i do have a set of Straight jackets..... are you saying im a terrorist? You've got it all wrong though, white boys that look like roid munching asswanks only buy them in white.
An interesting opinion, because I think they are the only two models in the current plastic range that don't look like completely overdone arse-wankery.
Exhibit A, Juliet:
What's with the gay bit sticking out in the corner? FFS, they would be good if not for that. Same deal with the pennys, except they are even worse.
Exhibit B, Jawbone:
What wanker would be seen in those?
Exhibit C, all the rapper/gangsta spec big square shit things:
And all the other models that fit that category too...
And then the half frame ones, I can't stand any of them:
Straight jacket and minute seem to be the only sensible ones left. Agreed though, old minute was much better (as was old straight jacket).
I think I'll definitely get a set of the square whiskers, although I'll sleep on it and decide tomorrow. May get a set of minutes as well for the odd occasion I have to do something sport-like :P
You are a terrorist. And yeah any plastic sunnies in white definitely makes you a cocknugget roidhead
That's where the screw is to hold the lens in. It's stronger having it there instead of being the same one that the arms swivel on.
They're probably the most comfortable sunglasses I've ever owned too :P
The Pennys are smaller than the Juliets that might be why it looks more odd to you?
Edited by Isola
yeah, i've officially re-assesed them, since they are metal and that knob is functional, I like them :P
a little on the pricey side though :) EDIT: And none with black lenses without going "custom" (uleh)
looking on ebay now...
Edited by Smity42
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
