Haven't posted in a while, I know you've all missed me. Moved out and haven't got around to calling up tpg yet, however I "gained" access to another network in the area.
Looking at importing a car in the next few, so many choices!
Welcome back :D
That 33 still dead?
What's top of the list?
RE porka brakes:
We have concluded our investigation into your case and have decided in your favour.
We were able to recover $530.00 AUD, and this amount has been credited to you. Please allow five business days
I really wanted those brakes, but at least im not out 500 bux I guess...
Welcome back :domokun:
That 33 still dead?
Hahah, replaced the coil pack, wiring loom and the spark plug and shes all go again. I told him to go get a series 1 coil pack, and wiring loom.
He came back with a series 1 coil pack and a series 2 loom.
Im thinking either 32 gtr or 34 gt r or gtt. Since its my first car off my p plates Ive been leaning more toward the gtt.
By the way, anyone who uses firefox here, when theyre replying to something and hit the apostrophe key does it bring up a find field?
at least it's all fixed now
are you sure you need to import a 34? there's a fair few of them here already. Fair enough if it's going to save you a heap of money, but otherwise it might be better to buy local?
no search field for me
I don't think it would even save you money importing a 34. All the skylines have been brought over in large numbers you may aswell buy one local since they are as cheap if not cheaper over here anyway. Only way you would want to import one is if it was a one off, low ks full logbooks collectors item.
Morning mangs
Morning mangs
Your up early.
How was the weekend ?
Your up early.
Up this time every morning :banana: Normally its a lot busier in the morning so I don't post until all my subbies are started work etc. Hardly got anyone working today :banana:
Weekend was a great success :)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
