just went through my first ever defect station
anybody want to take a rough guess at list of defects, if any?
no defects.
cop "does this have a blow off valve?"
me "......no?"
cop "rev it"
rev no whoosh, rev no whoosh
"you're right, keep driving"
I IS SOO JEALOUS OF YOUUU
nice one brother <3
when i had my android, i topped out one month at 700mb. but rarely went over 500mb, and i flogged the data on that thing. even when at home, id use that data not my wifi.
Seeing that makes me a sad panda... I'd ALMOST be tempted to take it off his hands (for free) if he gave me everything I needed to undo what he's done.
wtf happened to the engine?
It was sold with the car back in 2005.
Someone from Secret Drift ended up with the motor.. As a box of bits. Someone along the line gutted the tastey bits from the motor and sold the poor kid a dummy more or less.
My housemate has come to the conclusion this house is haunted.
On top of our fridge there's one beer bottle for every beer we've had (long story) anyway, so during the night they all crashed to the ground when we we're all asleep but it woke us all up as well from upstairs. I would have thought it was just the compressor has kicked on and its shaken the fridge a bit and caused them to topple.
So last night they thought it'd be a grand idea to get out the faithful and foolproof ouija board. They are all conviced the house is haunted and there's a ghost coming to f**k shit up etc.
Ideas on scaring stoner housemate?
ok, so today I headed along to Lakeside for the Legends return.
Awesome cars, lots of sun and a few crashed. The best bit of the day was sniper boobies.....
That is all.
I agree. Group A is awesome.
The photographer was my mate Craig. After you guys left, there were 2 accidents at the end of the main straight. Both cars drop a rear tyre in the dirt on the right hand side of the track and ended up spinning into the tyre barrier.
I know Craig got a few pics, I'll see if I can get a hold of them.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
