"Never tell me the odds"
Fast and the furious 5
Its going to be bad isn't it ? :blink:
It can't be any worse than the second one. That's the worst one so far.
ENGINE FARKIN OUT!!
Stop it!! :)
for Tony
you know you want them
Do it!
i never had a group
That's what she said
more noise?
I found it simple, although actually having intelligence helps.
You can't put brains in cabbages
BBBBRRRRRRRRRRAAAAAAAIIIIIIIIIIIIIIIINNNNNNNNNSSSSSSSSS!!!!!!!!!!!!!!!
*Automotive Family Tree*
Where's the link between Ferrari and Team Orders?
This assumes useless sped zombies, not awesome zombies such as those found in L4D2. It is also disregarding the sheer weight of zombie numbers if 90% plus of the worlds population turned, not to mention the deceased that might rise again...
Ahh come on, its got Ludacris in it :)
9-11 conspiracy nutjob
LOL!
Equally flawed logic. I could scientifically refute every point made, but I can't be arsed. This bit:
"LOOK THERE'S A DUCK! MURDER IT!"
Belongs on quacky's faceparty page :ermm:
Comparing two phones. Guess which one came out on top.
As above
Relatively unsurprising result. The only real surprise was that the iPhone managed to score a point.
O+P+T+I+M+U+S = 15+16+20+9+13+21+19 = 113 is a Prime number; Optimus = Prime. Headsplode :blink:
There is so much win there it isn't funny
Gaaaaaaaaaaaaaaaaaaaahhhhhrnnn!
Looks like basically the same cast from the second one, + the rock. Could definitely be worse.
Stop it!! :(
Morning mangs
GERMAN TONIGHT!!!!!!!!!! :blink::):ermm::D:D:D
Yes.
But if people watched it for nothing more than entertainment there would be far less tech talk on what they said wrong on forums.
Movies are shit, but amusing
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
