Blasphemy!
A minor blasphemy, easily forgiven (We did have a Milton Reformation).
Going elsewhere or some other time and then saying "X was > Green > *" is a different story.
Hmmmmm...... OK then
That would be a keel-hauling offence
In order for X > Green > * a unanimous decision would have to be made by impartial judges after thorough investigation of X. Agree?
NO! X can never > green as long as the one leg is both the same. :action-smiley-069:
A thorough investigation of green and all it's surroundings would also be required. I volunteer myself for all required investigations
f**kin lol Martin. Nice work.
Just had epic argument with tiler/glue seller guy. He's a douche.
I had an epic argument with a builder yesterday afternoon. Apparently windows 7 should be covered under warranty, so when he f**ks it up he can bring it back for me to spend 5 hours fixing and he won't have to pay anything for it. So I put the question to him, if I got him to build me a house and then I knocked a wall down inside it and the house falls down would he have to build it up for me again?
Ah but then if it could be ascertained that the one leg is both the same and the impartial judges ruled in favour then it could be established that X > Green > *. Correct?
I concur. I believe we should organise a committee to proceed with aforementioned investigations.
Finding impartial judges is like f**king for virginity. :action-smiley-069:
http://www.youtube.com/watch?v=7ya-v-jchr0
R34,33,32 review on top gear from way back. I haven't seen this before so maybe some other guys haven't either!
yes colin he did, its currently been sitting in the workshop since monday arvo though with a coolant leak from a turbo line, its almost an engine out job to replace this 4 inch length of hose!
It's not too bad, taxi spray red but generally a clean car couple minor mods here and there, although he wants these modena rims.
Also tell your dad to buy that cortina, and i'll remember to bring some empties for you tomorrow night
Happy Birthday John. Rock on I says
Cheers mangs!
Not feeling the <3 no more..... :(
And
HAPPY BIRTHDAY JOHN!!!!
if you didn't see it due to post skimming........ :action-smiley-069:
Edit: Happy Birthday John! hahaha.
:D
That's the S1 review from the silly fat fucker that Martin and I were talking about.
Not feeling the <3 no more..... :)
And
if you didn't see it due to post skimming........ :(
Didn't see it! Was skimming! Sorry
Mucho thankies and epic <3
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
