funkymonkey
Morning Mangs,
+1
Been here since 7, for that entire time managers have been sitting here with their morning chit-chat routine, preventing me from wasting time on SAU etc :D
How was the weekend?
Good. Won the WDC in a williams, and got a drive in a red bull alongside hitler's youth for next season. G27 is kick arse.
Also regreased all my bushes (that's what she said), car is considerably less squeaky now. Brakes still a bit squeaky and so are the front swaybar links. The swaybar links are pillowball with no grease nipple - I'm not sure how to lube them up. Ideas?
MTB is at the shop to day to get the gears adjusted and brakes fixed up. He didn't seem too optimistic about the brakes though :down:
Sounds like a successful weekend. It was raining all weekend on the coast so I did some assignmenting at uni on Saturday arvo then went home had kfc watched movies and played poker. Sunday I did all my shopping and cleaned the unit then played more poker lol. Played 6k hands and broke even. So lame.
Good moaning.
Morning Mangs,
It was ok. Got stuck inside on Saturday due to the rain and had to watch the AFL GF. It wasn't so bad as I had beers, chips and other assorted artery hardening food stuffs.
Moar grease on teh brakes?? :D
The only way Ican think to lube up the swaybar endlinks is the remove them.
So glad I didn't have to watch either of those GFs... GayFL FTL.
Yeah need to borrow Dan's copper grease again so I can lube them up.
I can remove them, but how to i get grease into the pillowbally bit without a grease nipple?
Nice fail recipe
Mangs,
Weekend was decent. Went to Movie World on Saturday and got some cool t-shirts. Watched some LOST and ate KFC on Sunday.
TAFE is boring today. All repeat info on OH&S. Might pass the time with some Stephen King.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
