funkymonkey
He wears a lab coat, he must be trustworthy :P
Yeah he seems legit :P The stuff I get is called Gippsland Farm yoghurt or something like that. It's the bomb.
Sup all! Thought I'd stop in and say hi :D
Mang *tips hat*
Unlucky. Shoulda bought those tyres I was selling...
Yeah probably but they would of been too big. My fronts are 205/40/17s
I saw a red WV on the way home, red personal plates "RANGA". I thought of you.
Lol I need those plates.
Nothing I love more than an old fashioned hole stretchin'! By gar it's been a while!
Keen.
Since my last appearance here, I have come across quite alot of free shit. Won an esky at nightowl, got a free 46" plasma, got a free bottle of jim beam (it all counts!) and got a free insight into what it's like to be on the other end of an angry kiwi.
And quietly, may land myself in some hot water with Sony. Something to do with my flashing of usb dev boards and selling them so kids can play backed up games :\
Edited by hylian
Sounds like an interesting few days mang. When you coming out for some more JB and ice cream?
That's what she said
<3. I knew someone had to jump on that one :)
Yeah but not when I'm only replacing one tyre lol.
Wait, you replaced ONE tyre with a cheapo KENDA? :down:
Mismatched tyres FTML
Oh yeah tyres for the 32. KU36s or RSRs?
RSRs for sure. But neither will last long on a daily. Recommended KU31s over SS595 for a daily. KU31s definitely have more grip, yet to see if the 959s last longer though...
RSR's are a nicer tyre
Truth.
if that racist loser didnt but in tonight i would have told you that
How do you but in on yourself?
i think rsrs are more baller though
You know it
Tried and tested and you know they grip like a mofo.
Indeed.
:down:
time to go to bathurst, later...
got a r35 passenger ride on Thursday, im jealous of myself... :)
edit: just thought you might wanta know... SAU understands, FB does not...
Thats awesome. Martin is jealous.
Nice score col. Now hurry up and buy a GTS-R and sell me the exhaust manifold and heatsheild from the RB20DET-R
$5 if he delivers?
mang in, mang out
Thats what she said.
Morning mangs.
Anything cracking for bathurst/F1 on the weekend?
P.S. I just wanted to put this PS in...
P.P.S. So that I could put this PPS in...
P.P.P.S. Just for Jason ;)
<3. I knew someone had to jump on that one ;)
Truth.
You know it
Indeed.
Lowballer 31 ness means yes I had 1 kenda cheapo tyre on it. 3 week wait on KU31s so just took anything that was the right size lol.
Yeah I spose it depends on my work situation in the new year. If I'm working, living and going to uni in Brisbane then the GTR is only going to get driven 2 or 3 times a week anyway.
$5 if he delivers?
Morning mangs.
P.P.P.S. Just for Jason :D
Ugh got f**kloads of uni stuff to do this weekend so will probably just watch it while I'm doing some assignments. Gaids.
Morning Mangs
I may just come down this week, it really depends on work though and whether they pay me or not, if I do plan on coming down I'll let you know cause I'd get lost going there myself.
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
