funkymonkey
The cheapest one I've seen was 13K
That's what has me reconsidering as well as the issue of availability of standard replacement and aftermarket parts
I remember when I used to hunt for parts for my 205 gti, everything seemed like it was coated in gold. had a quote for $900 for a new set of radiator hoses. for rubber fucking hose
hence I will probably end up buying one of the old mustang shaped celicas and have fun with that.
The only thing I don't like about them though, is the engine bay is not as generous as in the 240z
Sink another 20k into the GTR. The depressing thing is 20k doesnt go very far lol.
I'd imagine it would make it a nice streetable GTR, I have no idea about the cost of parts on those though.
im actually the same as Martin, I would like another 20k to sink into mine for brakes, new suspension, track rubber, carbon bits and maybe some bigger turbos :mrt:
Word for word excactly what I would do. :D
A great story for sure.
They will all get pots of money too for selling their story to the media
there isnt enough money in the world to entice me to go through that soit.
I hope they make huge bundles from it.
If you told me in advance I was going to be stuck in a cave for ~65 days and make a few million dollars I would do it in a snap.
If you told me there was going to be 32 mexicans in the cave with me I'd probably make you double it :)
But yeah, being stuck down there and not knowing when/if you will ever get out would sure suck. Definitely hope they all make good coin.
In other news, Duke Nukem Forever might actually be released?
http://www.news.com.au/technology/is-duke-...0-1225938292750
F*CK YEAH XF! Duke FTW!
Gearbox are the perfect company to do it too, it might actually happen this time :ninja:
and wasn't there one fellow who had his wife, mistress and possibly a third girl waiting for him to be brought out.
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
