Apparently the peak is 2:36 now, they keep changing the goal posts lol
Water didn't look high at all at 12:30... mind you i am down at Murarrie
Miso - where did you get your tartan handbrake/shifter boots from and would you care if I rocked them too?
Had them custom made. Think it cost $60 from memory. Have the details of the place that did it somewhere, if I have a look around
Have plenty of material left over at home if you want to use it.
Sink another 20k into the GTR. The depressing thing is 20k doesnt go very far lol.
Depends where and what you buy, and who you get to do the work.
20k could get you a seriously fast 32 GT-R even if you started from stock, but as you already have a fair few sweet mods it would go a LONG way.
Think about it, start with a stocker;
sell the 26 bottom end
sell the standard cooler and piping
sell the standard injectors and fuel rail
sell the standard fuel pump
sell the airflow meters
sell the standard turbos
sell the standard dumps and exhaust
sell the standard ecu.
I would think there would be a few grand in all that.
Now, doing all the work yourself you could have a built 30 bottom end under your 26 head with 4wd adapter for 7k or even less I'm sure.
now go buy 1000cc injectors, fuel rail, fuel pump(s), intercooler and pipes, -5 turbos, nice big exhaust system , ECU,boost controller. I've probably left things out but i think that would come in under 20k and you would have a 400awkw GT-R.
Mind you this would be ghetto spec modification.
Edited by Nee-san
Oh I'm sure I could make 20k stretch a fair way if I wanted and you will find some bargains along the way. The problem is then that you now have a 400kw gtr with standard brakes and suspension and I could easily eat up another 20k there lol
I'd be content with just having the gtr back on the road again. Fit the new front pipes and get decent cat and some new brake rotors n braided lines.
If you could find the details of the place for me that would be awesome. I thought they were an 'off the shelf' type of thing. If they're custom I'll see if I can track down some of my family tartan to make them out of. If not I'll find something else epic to make them out of :D
Morning Mangs,
John and Noel, you missed epic-tits-arse-legs-body redhead girl that came in for ice cream, wearing skintight black workout gear of some sort that left almost nothing to the imagination. She single handedly made up for all the fail from the rest of the night, especially when she bent over :D. Oh, and she was a P plater.
TFIF. I should be able to go home around 1:30 :)
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
