always
hairy muff
i like the ribs i just ate at the petrie tavern... $25 worth...
best ribs ive ever eaten in my life... had to thank the chef, was super impressed...
hairy muff
Should have come said hello
I refuse to go to the petrie tavern... it screams dodgy :P
local also hey?
i thought the same thing, but the food was amazing for a pub/tavern...
heaps better than warner, lawnton & albany creek tav's... their pricing is also very reasonable for what you get...
i will be going again...
If thats the kind of loves that get dished up in here... Count me in
face sex?
local also hey?
Yeah I'm about a 5 min walk from the tavern. You around this area also?
I might have to actually check it out based on your recommendation
We're all relatively local (those of us that count)... Tavern night?
You home tonight, Mang? Lyss is going to Zumba at 7, so I could come up and fix it if you want.
Sorry mang, I didn't see this until too late.
I have no magnetiz'd that screw you dropped though, and vacuumed all the crap. I should be home the rest of today and also tomorrow morning.
Or you can just do it whenever.
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :P
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :laugh:
Busy this weekend, that's why I was asking about last night. I can come over after tafe one day if you want? Or I'll just give you the bits on Thursday. It's not much damage at all. 8 screws, one bolt and 6 clips I think was all that need to be done up again.
Yeah im in Warner...
The warner tavern is too upmarket now (in terms of pricing) their food is ok, but not worth what they charge...
So we've been going to PRMBC & the lawnton tavern lately... But found a shopper docket for buy 1 meal get one free @ petrie tav and thought "hey why not give it a go"...
So two main meals, an entree each & 4 or 5 drinks later $42... Happy days...
Then the ribs of my life... It was a very good night...
Yeah id be up for it... small crowd would work, not much dinning space in there...
The ribs are all ive thought about since Friday...
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
