Hahahaha MARTGATOR you old dog, you!
Working...... then hopefully some beers.....
Go on. Approve that. I dare you.
Just watched that Top Gear where the go through 'Nam. Pretty boring until they make aqua bikes...
Saw the shopping center thing too, but that's not what I was talking about doing with a swift.
Good work good price, got my cage done there.
http://www.scottsrods.com.au/
they did the exhaust system for my SS a few years back
was worth the drive out there, the quality was better than most and very cheap compared to others for the same work...
they came recommended to me
Phantom Motors... ewwwwwww
I hate car photos that are taken on stupid angles like this one:
How hard is it to line the camera up? Why do they take such stupid shots? It usually hurts my head to look at them.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
