How? With his car
What? Ran into me
When? Last night
Where? In the car park
Why? Because I was standing in front of the car while he was parking
It's pretty bad hey... Doctor says I will probably lose the leg if I don't come up with a white 32 GT-R...
Emotional stress as well, that's going to cost a lot for counselling...
Strip club?
I have (totally not bribed) witnesses though.
Lol sure why not. Thursday nights are about to get a lot more expensive though :D
Do the strippers have icecream?
Touche.
So Smity, do you want a nissan patrol too. Just stand in the car park next week and I'll organise another law suite for ya. :D
Sounds good, has got to be a better tow car than the sexF :)
Lol sure why not. Thursday nights are about to get a lot more expensive though :P
Worth it. Totally.
Sounds good, has got to be a better tow car than the sexF :devil:
I saw that thing on Top Gear... I shuddered a little.
someone build me a new pc while the dollar is good. Dual monitors, decent sized hard drive, able to run auto cad 2010 with dying etc. Budget $1500 incl screens. 2 x 19/20in monitors would suffice.
no
so what's the plan for next week's meet. we need to concrete in a venue
kfc indro? lots of parking, lots of seating? or even the maccas or hungry jacks on moggil. big carpark and a big outdoor area?
Since when is there heaps of parking at KFC at Indooroopilly?! ;)
I was also thinking Taringa Hungry Jacks might be a good idea though (if that's the one you meant)
Fark. You're not going to get much around that price my friend.
Autocad is pretty intense and since you're after something with 2 screens as well you're gonna need to set aside 2.5k for a half decent one.
Here's something I'd reccomend, which would keep you out of trouble for a while.
CPU: Core i7 950
Mainboard: Gigabyte ga-x58A-UD5
Memory: 6GB Kingston DDR3
Hdd: 2x Seagate Barracuda 1tb SataII
Optical: Lite-On Blu Ray IHOS104
Video: Gigabyte Radeon 5870 2GB/850mhz/DDR5
OS: Windows 7 64bit
Thats around 2100 with 100 for me to put it together with a case and an antec psu.
Then you add the screens
2x Samsung LED 20" $450
This is a rough pricing though, so it may end up cheaper than what I've put down here but yeah if you have more money to play with I'd have a bit more leeway in parts etc.
Edited by hylian
Yeah... what Keaton said. Be less of a jew.
2 x 20" screens for $1500, not a problem. Or computer to run 2 x 20" screens, but not actually having any screens also, not a problem. Both together = Spend more.
Edited by Isola
CPU: Core i7 950
OS: Windows 7 64bit
Bah f**kin lame. Surely Autocad isn't that intense. I run it on my laptop now and this piece of shit is 5 years old. Intel Pentium M 1.73ghz with 1gb of ram. It runs it f**kin slow and I can't do anything else while I'm using it but it's semi usable. My comp at work uses 2 screens and that thing is a heap of shit aswell. Guess I will have to wait a bit longer :blink:
Well that was a fail of a mission to get that bonnet...... thanks Martin for the loan of the sexF bahaha
Might get it tomorrow murrrrrrrrrrrr
Since when is there heaps of parking at KFC at Indooroopilly?! :blink:
Yeh, the one opposite the mazda dealership. There next week?
Im sure you could run it on somthing far cheaper than suggested, the guys out at our workshops run it on really old school computers. Geeks always over specify when you ask for computer advice :(
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
