funkymonkey
I might be there tonight.
Depends what time my evening appointment finishes.
In Townsville yet again, bur i'm planning on making an appearance.
I went to stones corner baskinds last night and got an epic tub, so no need for me to go out tonight! Try the gingerbread flavour, its amazing
Well I'm not going to drive all that way (be it CH/Stones Corner/Greenslopes/whatever) on the strength of a couple of maybes. Anyone else going?
Been thinking about somewhere we can meet. How girly are people about not being able to see the cars??
IDGAF. As long as it seems to be a reasonably safe parking spot, I don't care. Others seem to though...
Just saying it cause i can, U2 is the shittest band, Bono is a cock, and the edge is a shit guitarist, all of his guitar work sounds the same. Plus Bono can't sing for crap live.
Bring on real talent, The eagles are next week
Morning Mangs,
Got attacked by one of those spiders with health bars last night. Lucky I don't have a handgun or I would have put a bullet in the thing. It was that big, Dan wouldn't even be able to miss it.
Greenslopes was pretty decent. Would visit again.
I'm going to have to bring my own chair if we keep going there, but other than that it wasn't bad. I will miss Grace^2 and Morgan though.
Also I would like to point out that the store is actually "Baskin Robbins Stones Corner": http://www.baskinrobbins.com.au/stores.php?state=qld
I'm not saying that Stones Corner is a suburb, but there is no rule that says they have to name their store after a suburb either.
Brandon, i couldn't resist flaming those flat faced lmgts :P
LolWut?
Hmm, should have read this before heading out. No ch love.
On a side note, new forums format is a heap better on the I phone
iPhail :down:
^^^^ This man speaks the truth
That's what she said.
Zombie survival.
End.
Edited by Smity42
Usually ALL the tables there are free and we all used to sit on the rails too lol
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
    • What does IPDM stand for ?
