funkymonkey
I got from the valley to home (bray park) along old northern road with no issues, on the radio at work they were goin on about how the valley was flooded we drove most of it and couldn't find a road under at 12pm today. There was more water flooding the roads at high tide yesterday then there was today at high tide. Lets see if i have to work tomorrow.
Oh if anyone on the northside wants somewhere safe to store there car send me a pm, no chance of getting flood waters where i am. Well most of brisbane would be under water if we did get flooded
Success! Got home and house (and cars) are OK :).
Low level brisge is out, upper brindge is split-laned.
Both under water now... Going to go for a ride and check it out.
I live near the river, but im about 6-7 m above bank level it is expected to only go about 1m above that so im not overly worried
Sounds like its going to hit a lot higher now! They just said 22m on the TV. I hope you guys are going to be OK, get your important stuff out and get to higher ground.
Afternoon all
Work's fine, house is fine, dads house (where I'm housesitting for around a month) is fine.
Chermside closed down, only the supermarkets are still open now. Gonna head down soon and get some supplies in case the supply route is out of action for the next few days/weeks
forget the shops
i went at midday and all the bread/milk and such items were gone... none left at all...
people were going crazy, the softdrinks isle and chips were empty and the line to get to the checkout was over an hour at midday...
i heard on the news most supermarkets are closing at 4pm due to lack of stock and personal staff needing to leave...
forget the shops
Petrie woolies still open and plenty of stock...
...unless you want bread, milk, eggs, meat, or vegetables.
Oh well, I have a loaf of bread in the freezer. NFI how old it is, but it'll do for sammiches for lunch :)
What's the road closures like?
I need to get to Nudgee tomorrow at 11....
Might have to look up the locacl council websites in the morning and find some open roads
Just got home from work. Had to go back and sandbag the office and get all the files and computers out of there. I'm still in tomorrow at 6:30 though lol. See how we go tomorrow. My mate has had a look at the map and found that our place is right on the edge of the floodwaters so i might need a place to store the car lol.
try get in, but if water is on the road don't bother.
That's what she said.
You can leave it here if you want ;)
Yeah Colin, the inner west will be rooted if it goes 70's spec. Move your car if you can.
We all have to go in at 8 to lay tarps and put down more sandbags. I'm wondering if I'll be able to even get there if Kedron Brook keeps rising...
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
