I got from the valley to home (bray park) along old northern road with no issues, on the radio at work they were goin on about how the valley was flooded we drove most of it and couldn't find a road under at 12pm today. There was more water flooding the roads at high tide yesterday then there was today at high tide. Lets see if i have to work tomorrow.
Oh if anyone on the northside wants somewhere safe to store there car send me a pm, no chance of getting flood waters where i am. Well most of brisbane would be under water if we did get flooded
Success! Got home and house (and cars) are OK :).
Low level brisge is out, upper brindge is split-laned.
Both under water now... Going to go for a ride and check it out.
I live near the river, but im about 6-7 m above bank level it is expected to only go about 1m above that so im not overly worried
Sounds like its going to hit a lot higher now! They just said 22m on the TV. I hope you guys are going to be OK, get your important stuff out and get to higher ground.
Afternoon all
Work's fine, house is fine, dads house (where I'm housesitting for around a month) is fine.
Chermside closed down, only the supermarkets are still open now. Gonna head down soon and get some supplies in case the supply route is out of action for the next few days/weeks
forget the shops
i went at midday and all the bread/milk and such items were gone... none left at all...
people were going crazy, the softdrinks isle and chips were empty and the line to get to the checkout was over an hour at midday...
i heard on the news most supermarkets are closing at 4pm due to lack of stock and personal staff needing to leave...
i have drawn inspiration to download the old kevin kostner movie "water world"
5% complete already, give it another 20 minutes and ill be getting educated on what may be next week...
forget the shops
Petrie woolies still open and plenty of stock...
...unless you want bread, milk, eggs, meat, or vegetables.
Oh well, I have a loaf of bread in the freezer. NFI how old it is, but it'll do for sammiches for lunch :)
Pictures from the Pine River at the Petrie Crossing.
The bridge (that actually crosses the river) is way in the distance, past the "Petrie Mill" and speed limit signs visible in some pictures.
And a vid:
What's the road closures like?
I need to get to Nudgee tomorrow at 11....
Might have to look up the locacl council websites in the morning and find some open roads
Yeah not worth going anywhere.
I luckily work 5 minutes from where I live, and there's no creeks between those two points hahahaha
Just got home from work. Had to go back and sandbag the office and get all the files and computers out of there. I'm still in tomorrow at 6:30 though lol. See how we go tomorrow. My mate has had a look at the map and found that our place is right on the edge of the floodwaters so i might need a place to store the car lol.
try get in, but if water is on the road don't bother.
That's what she said.
You can leave it here if you want ;)
Yeah Colin, the inner west will be rooted if it goes 70's spec. Move your car if you can.
We all have to go in at 8 to lay tarps and put down more sandbags. I'm wondering if I'll be able to even get there if Kedron Brook keeps rising...
The call for work tomorrow is, try get in, but if water is on the road don't bother.
You have a bucket of water ready to splash on the driveway.
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
