I've run out of crayon's though.
Nikko pen will be acceptable
Jason you keen for German club?
Suspended in my work = sacked lol.
What time?
sacked,suspended, given the arse and getting a DCM all the same thing.
yer suspended at my work normally means escorted off the premises, they know we have sticky fingers and will take anything even if its bolted down
Although the word mistake at my work can range a fair bit, anywhere from a talk from the manager to a court case for manslaughter
I have a lot of colour pencils. The project manager saw me marking up scaffold drawings in coloured pencil and he was like
PM: Are you marking up drawings in coloured pencils?
Me: Hell yes
PM: You do your planning in coloured pencils?
Me: Hell yes
PM: f**k yeah I love coloured pencils.
Me: Hell yes
Me: Hell yes
Lol
and, anybody got an angle grinder I can use, or that can do a slight trim on couple of choice metal bits on my car.
cage is being a real pain in the ass to install
one long pain in the ass
jason i think what you are looking for is called "bailey channel" Im not 100% on this but pretty sure its near enough for someone to know what your talking about
I has angle grinders
you coming to german club tonight, and if so, are you going past your place first?
I just have one support bit where the sunroof used to sit fouling against the cage, so just need to trim it by about 5mm
Had a morning tea this morning to raise funds for the qld flood appeal. Everything that got donated Brookfield is going to match. So far from the head office sites in Brisbane we've raised nearly 13 grand. Solid effort by everyone :cheers:
Or, I can swing past your place at some point in the week and you can have a crack, as I haven't used an angle grinder before....
I am, and I am home now. Can bring it if you want. Angle grinder on the train will be baller. Just let me know coz I don't want to bring it if you don't want it.
If you like, although I can take no responsibility for unwanted metal damage...
Awesome stuff. Powerlink is also matching donations dollar for dollar. Was just over 20g this morning.
also keep genitals away from the spinning bit too
Since when are genitals not body parts?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
