Martin f*cking lol at that thread. If old mate pays more tax then you earn a year i think he should throw me a couple thousand to play with too.
Ravi, baked beans can pressure tester sounds like an awesome tool, air leak anywhere in the pressure side of the system will cause you issues. The other way i have seen for checking for boost leaks is pretty dangerous, it involves removing bonnet, a back road and holding on tight.
Edited by Dan_B
I think Noel is definitely a better Troll than me...
Keen.
HAHAHAHA I feel like we should try that method
f**k I love skylines. I was down the back end of the warehouse and I heard out at the street the biggest, fattest spool, screeching of tyres, screamer pipe, EPIC atmo bov... and run out and she was gone :( ... but was definately an RB :worship:
just replaced the rear shoes and brake cylinders in the parents car, it shows i don't do much with drum brakes, took me 3 hours to do it.
urgh cant seem to multi-quote with the mobile forum, fail.
@Dan:
A - drums are shit.
B - you had plenty me practice on the xf, should have been able to smash it in minutes.
@Ravi: that's what she said.
@Miso: tfif +11ty
Yeah the iphone version of the forum is severely lacking key features
-Page numbers
-ability to multiquote
-tits
We can fix the last one easily enough
Carpark meets with dodgy folks.
Defected for not being one of the miniorities.
Still have the same defects on my car currently. Couldn't be arsed to get rid of them yet. I've grown attached to them <3
Morning peoples.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
