Anyone know the size of the throttle body rubber/silicone joiner on RB25det? is it 70mm diameter? by about.... 4 inches long??
Got a split when I changed the turbo... replace it and see if there's any improvement
Public holidays are 250%
I will have fun basically rewiring my car ! LOL
Took tonight off as I'm working strayan day.
What is up with you mangs ?
work on straya day n get the double time pay then take the Thursday off instead? Sounds like a solid plan to me. Profitable aswell.
Now that is strayan thinking. Nice work!
I was going to wear and aussie flag as a cape and beat up minorities. Anyone wanna tag along?
Seriously though. BBQ somewhere?
f**k yeah. Keen to beat up some injuns.
To you? Probably.
I can't help it if she doesn't like mario brothers...
Anyone go to Lakeside yesterday? Went out for a few hours, saw all the cars but standing in the sun being roasted like a lobster got old quickly.
Didn't know it was on.
big thumbs down for working a strayan day though. Wait ? Is it really a strayan day? I thought strayan days were chucking a sicky to go fishing and such like. Hmmm... me thinks this could be a fake strayan day.
*HEADSPLODE*
Truth.
Sure you don't want to get a southern cross tattoo or something instead? :thumbsup:
Any one seen any R32 GTr brakes for sale recently? Just wondering what they are worth!
Swaps for a garage door?
HI
Hi :action-smiley-069:
$300 - $400 for callipers and rotors off the top of my head. they are roughly the same size as r33 gtst brakes.
Mangs.
At band practice. Band still not here. Lame.
Make like a bass guitar and be inaudible.
Have hit a brick wall with guitar. Haven't found anything interesting or challenging to play, and if it is challenging it's way to hard.
$475 for DBA rotors.
Have a set of them on the coon and they go alright for pulling up a barge. Better than factory anyway; bit more reassurance when heavily braking down a hill.
Ravi: A split at that connect would most likely be causing you an issue. As for what i have for sale.... uh 33 parts? Diff, Nismo clear side inidicators, and a S1 RB25DET ecu. Thats all i can think of at the moment.
straya day plans?? im really keen just to drink somewhere.
John, should be more awake in the mornings, if i see you again expect epic alfa horns from my skyline
Traffic is blocked off due to a fuel tanker trying to drip around a motorway feed ramp..... obvious occured. tanking pancaked and dropped it's load.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
