7:30 to close. I won't be there this week, will be next week, hopefully with my baby once more :) Just have to pray that work doesn't dick me around and I am able to pick it up sooner rather than later.
I'm pretty much finished mate. It's all up to the ECU now. That get's done tomorrow as long as there are no more holdups - holyf**kenshit I hate japanese instructions on intercoolers that are supposed to 'bolt on'.
YEAH RIGHT!
I'm sorry if it sounded like I was having a crack at you for the delay, not my intention at all Dan! It's my work I'm worried about mate :( They just decided to fire a manager so it looks like I'll be doing more than a few extra shifts for the next few week. It's just a matter of when I'll have a day off next week to come and pick her up and pay you. I won't know that until tomorrow night but hopefully it'll be early in the week, other wise next Thursday (the 7th) as I have the day off to go to uni but that doesn't start until noon so I could be there in the AM.
I'm super appreciative for all the work you guys have done and can't wait to have my baby back. You've been great with me, could not be happier!
And sucks about the non bolt on "bolt on" IC. Hope it wasn't too much trouble for you!
Yeah not a problem mate, always glad to help.
It was only a very minor mod at the end so not a big worry.
I can arrange something like driving the car to your place of work or something similar. I am able to get lifts from just about anywhere and if it means less hassle for you, then sign me up!
ERD Dan, if you see this post:
What options are there for side mount intercooler upgrades for my R32? Do Z32 side mounts fit?
I keep trying to give you a call but have been flat out at work all week :(
Edited by Isola
Dont lie.. you havent been busy at all. ive seen you sitting in cars trying to look busy :nyaanyaa:
ARC side mount
pretty sure r34 ones fit as well.
Seen a few ARC r32 ones floating around in the classifieds section for reasonably cheap
I like this guy.
Work is giving me the shits yet again. I've probably done 7 hours work over the entire week. I'm all for having a good sit down but having a sit down and F5-ing all day gets to me.
I'll trade you jobs. I do 50-60 a week and it's going to get MUCH worse in the next few weeks. Thank god I love what I do so much :)
Yeah it must be so much frickin hard work eyeballin all the pussy every day. Quit ya whingein!
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
