Quite possibly a little end bearing which is not as serious. I didn't get a chance to hear it to confirm but I will if I'm up there tomorrow
Thanks.
I've had my doubts on the quality of the rebuild that engine got for a while now...
On a more positive note, I did rub my nuts on the left rear quarter of your car for good luck today. Damn clean car mate, well done!
and I'm not joking, I actually rubbed them on your car.....well, through the shorts.....but damn that fabric is thin so I reckon it's the same
LOL. I'll make sure not to wash that qtr ever again ;).
Thanks though :D it's good to see SOMEONE around here can appreciate a 31 :thumbsup:
I'm suprised it's held together this long, built in a st lucia garage by a bunch of drunks, i wasn't even a qualified mechanic then
pfft, sif nobody appreciates it. that 31 is the reigning sau show and shine champion
:rofl2:
31's are all good IMO :D I think I saw yours the other day when I went to drop something off to Whitey... Is yours the white one?
dan, thats like a chick whos had a face lift and butt implants... do not like
if only she had a boob job, it would look great...
lol... Yeah def not something that i would drive but interesting none the less
I am just counting down till 1pm. Have a meeting, which is the only real bit of work I get to do today.
Until then, surfing the net, and playing on my iphone.
I'll take your shroom ;-)
If you do want it, I can probably grab it off Dave and bring it for you on Thursday. Save you a trip.
Still have shroom if you need it. ;)
haha yeah sounds similar to my day.. I do have tafe work I could be doing but Im not really in the mood :/
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
