what suburb are you guys in?
Who's that directed at?
Martin what phone did you get? I read a review on the first of the 4g androids the other day, apart from battery life draining in a few hours on 4g it looked pretty good
red maserati?? hardtop or soft top?
we had a 4200 GranSports yesterday and i think there was a GranSports Cabrio there too.
It was a soft top. Parked up at the rail with its bum to the street.
that would have been the cabrio, i did some work on that thing, not too bad at all, sounds nice. Engine from them will fit a skyline engine bay
Haha awesome!!!
Speaking of engines that fit into things, I need to run an idea past you at some point. Unless it's an LS engine, no one at work knows or cares.
you :P
I can see if one of our offices would take someone on for work experience
you :P
Haha, she's in Albany creek, she's public transport literate. I work in the city and travel caboolture train line so transport generally won't be a problem, unless it's in the middle of nowhere.
Morning Mangs
No ikes cream tonight. Going to support the dirty old man. Although I won't be able to vote as I'm not a member and I have no money to become a member until pay day :thumbsup:
bishes
out for agm and probably ice cream as well. shit to do, people to kill
Get pics. :thumbsup:
p.s. if theres any looting, pillaging, or raping involved gimme a call. :cheers:
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
