How much are the Khumo's at Option 1?
Going from memory (it may be the other way round) in my sizes (215/45/17 and 235/45/17) it was something like:
595SS => F $110, R $120
KU31 => F $120, R $110
595RS-R => F $180, R $180 (on special)
Prices per tyre, plus fitting ($5-$15ea depending on if you want them balanced or not, and if they are on a car or loose wheels)
So in those sizes, the SSs and KU31s end up exactly the same price for a set of 4.
You want round phat black babys ? :O
Round phat black sticky babys :thumbsup:
Whilst the khumo might stick a tad better than the feddy SS just remember the SS will run rings around it in terms of mileage.
As an allrounder I still rate the feddy.
I'm not finding that. My last khumos lasted about a year. The SSs look like shagging out in about the same ballpark.
The SSs might have more meat left in the center when I'm done with them, but that doesn't help me if the edges are on belts :P
You're doin it wrong. :whistling:
There's nothing more I can do to reduce the camber wear on the rear. Its the nature of the datto-spec IRS. I have already spent a small fortune getting the base camber reduced as much as I can, but its still a tad over 2 degress, and it's still going to camber the f*ck up when it squats.
I could change the alignment on the fronts to make the tyres last better, but why bother when the rears wear out faster anyway? I like to keep the camber high enough to balance the rears, and I like a little toe out.
Ahem...cough cough.... GET A 33.
MWAHAHAHAHAHAHAHAHA
This could explain the stormtrooper walking down st pauls terrace with a suitcase this afternoon.
You guys should drive thongslappin' fords and holdens, you only need a good tyre on one side at the rear to get traction in the wet!
Epic night!
Ben (Homo) should get on here more often, then he would have something to do while waiting for his girlfriend to get really smashed at a work function
tears.
Very much so :(
The choice of who to but it from came down to two stores
Store A was slightly more expensive, but their website seemed more professional and they responded to emails quicker. They also guaranteed my phone would be shipped as part of their first batch of stock.
Store B was a bit cheaper, and they weren't sure how much stock they were getting in the first batch so couldn't guarantee they would have enough.
I went with Store A... Store B ended up with a truckload of stock, and worked through the public holiday and got almost all theirs shipped on tuesday. It seems most people who ordered from there's phones are in china already.
Store A has been dicking around, posting blog updates and emails on how hard their life is and how many orders they have to get through, and they hope to have them all shipped by the end of the week!
Backed the wrong horse... :(
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
