Erm... they usually go till around 4 or so... presumably will finish and then happy laps will start not long after.
They sell food there but it is crap and expensive. I usually buy it anyway though :P. You can bring your own if you want though. Suggest you bring a chair as well...
Didn't know if the canteen thingy would be open. I don't have a chair :(
drop past here on the way. I'll leave my fold up one outside. (I want it back though.)
I'd say a small hole in a radiator hose is a win for the club as far as damage goes. Much better than two cara going home on the back of tow trucks as happened last time :(
We'll have to coin the phrase
I've done a Boz
if any one of us busts anything to do with our cooling systems.... ;)
We'll have to coin the phrase "I've done a Boz" if any one of us busts anything to do with our cooling systems.... ;)
I did a Boz once:
Did an oil change on the chair. All the vitals are very healthy. Lovin it. :thumbsup:
WINNING.
    • I hope so.  It seems pretty nice. OEM feel the lot.
    • I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done.
    • Ist post I joined after seeing this thread  I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle.   I am about to change slave and fit a braided line to see if I can get a better result
    • I sent off a message to a guy, waiting for his response if he can do it or knows someone.
    • Just remake the bracket. It's just bent steel with a nut welded to it. It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places. The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
