Off to work now post.
Also, more track time = hells yes! I really need to get to work and lower my seat down so I can fit in while wearing my helmet.
I got lowered rail and seat... now I cant go far enough back :down: Getting some brackets made up this week.
Your seat will probably cease to be ADR approved if you do that. Also, you will need a mod plate once the brackets are fitted
yay for being short!!!! haha do need a more supportive seat tho bracing a knee against the tunnel isnt the bestermm.gif
Don't push me cause I'm close to the eeeedddggggeee
I'm try-ing not to lose my head
SARP. Just watched some UK documentary on GTR's. Was ok.
another one for you to watch if you havn't already.
Nearly finished my super greato awesome extreme terrific multithreaded loader app. Phear my l33t programmer skillz :P
I fear boredom is imminent now though :(. Might copy pasta my coupe build thread from 31 club to sauqld forum...
    • lol let me guess 10c lollies used to cost 10c too! prices have moved on old timer
    • The reservoir is pretty far from the pump, as others have said some of the pipe is also a rather janky power steering cooler. Find the leak. It might be the rack, might be a hose/pipe, etc.
    • looking at attached screenshot , I don’t know why there is a significant hose run for it to be looped backed into the steering   mine bas air in it and loads of it as when i power the car off loads of air come to surface forcing fluid out. I think my issue is leak or maybe hole somewhere like yours. I am going to drain the fluid and smoke test it   when i turn steering side to side it soften up little before getting hard and believe issue is air leak somewhere as pump is fine
    • It may not be relevant to your situation, but when I had the issue of air getting into the system on my GTT, I found there was a tiny hole in the aluminium cooling pipe. Enough for air to be drawn in, just not enough to cause a significant leak. Looked like the previous owner had chosen a bad place to attach the earth clamp of his welder and tried to mask this with a piece of mesh sleeving 🙄
