Ahh, one of them big magic fuses that actually supplies 12V hey?
yep.
been working on/off it for the last two weeks whilst doing other work. I now have 3 full days on it to get the battery moved properly. toss two battery disconnects in place (one drops the alternator inside the car.) take out the AC wiring, rewire the heater,rear demister and fix a lot of electrical niggles in it. right now I'm doing 0 AWG body earths on it using double jacketed flame proof wiring on the lot.
its a fairly full on job and I'm documenting a lot of it o camera.
And here I was all along thinking it was a battery that did that.
Where can I get one of these fuses Chris?
yep.
Sounds like fun. Keen for photos.
ppfffttt... batteries are so 20th century. Magic fuses are where it's at :thumbsup:
He's ok. Sore neck and collar bone but no visible injuries.
He's in a neck brace and on the magic puffer.
Car is most likely a write off. If Jeremy allows it can post some pics later.
Bags went off.
He was going straight, little old lady was coming the other way. Somehow failed to see him and attempted to turn right, right in front of him.
Don't think he even got a chance to brake.
Forgot to say, little old lady is fine as well.
Didnt see her before she was taken to hospital, but the paramedic said she was fine.
I have Jeremy's blessing, so will post some pics when I get home, 4ish
if he gets it back that will allow him to fix the cefiro :)
but yes that is definitely a write off.
Would be a pretty big job. n/a ceffy would have 4 stud hubs so would probably need to swap all the brakes and hubs out as well.
In the second shot you can see the ass end of the corolla wagon that the old lady was driving
forgot to take any photos of that, but it was worse off, with the whole front end completely crumpled in, with the windscreen broken, and the pillars creased.
Not sure,
I was taking photos of the car when Jeremy was talking to the cops
I could be putting words in his mouth, but I think he didn't even have time to brake, so 60ish, and probably 20 odd k's that she was doing.
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
