Damn it, $850 to rego the coon for another year. Tough choice, might be more financially viable to drive it into a lake.
Also, price on KU31s seems to have gone up. Going to have to get another set of feddys :(.
Did he actually think this???
"Heidfeld exited the pits, hoping that increased speeds would help extinguish the fire, but instead it made it worse and when he stopped on track the car's side-pod exploded."
So i think i have just found the best mountain run ever. It's from Queenstown to Milford Sound. About a 300km drive with about 150km of that being narrow twisting runs along the lake and rivers pretty dangerous in these conditions though, sections where you can't stop cause of avalanches and there is a tunnel a little over a kilometre long that feels like your going down into a mine.
On the snowboarding front it's been pretty good, good weather and good times, pushing harder on the jumps now to make some bigger air jumps. Another week and a bit here left
big cleanup for me today. place has been giving me the shits so out the big wheelie bin comes..
nah needed to clean and today was the day set aside to do it.
Quick question Chris,
My airbag light is on and no horn. i know it is the clock spring is broken, do you/can you fix this?
certainly can!! shoot me your chassis number so I can look it up and I'll get a price for you.
sent it.
Thank you Chris.
i work just up the road from you so if it isnt horribly expensive it will be easy for me to drop it off
need your build plate. fast is being a bitch. I have a rough cost on just over 3 figures for the bit and then a bit of time. I am making an assumption on the part number because I can't accurately look your car up.
i know it was 1/95 built. i will take a photo for you
<BR><BR><BR>I hope you can see that<BR>
Edited by Kiwibob
also the subaru *may* make an apperance on thurs night. just redid the rear suspension on it. have a radiator to do tomorrow and then its right to play with again.
In the 5 years I have owned the thing I have put 6-7000 km on it. (not to mention a $4.5k worked auto box!)
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
