my dad will buy this....hes obsessed with turning off that little LED on any appliance....even if it means loosing all settings etc.......:domokun:
Morning Mangs,
TFIT.
Northies are coming to visit tonight, so lets try not to park in the 15 minute car parks.
I just had to laugh at the marketing hype. It's an "ON/OFF" button - pretty sure monitors had them in the 90s.
German club is next week, not tonight :thumbsup:
ignition signal wouldn't be AFM I don't think, it could be coil packs yeah, or maybe a loom issue?
coil pack loom, have seen this exact issue in r34s a few times now.
I may be there this evening. Shall see how the energy reserves go. Have been getting 2-3 hours of sleep a night this week due to teething, so may well be napping.
LOL @ Samsung:
AN ON/OFF SWITCH!! AN AMAZING 0 WATTS!! WOW
Though that made me curious as to what a monitor actually draws.
This is an old dell 19" LCD under normal operation:
~36W
Press the power button on the front (same thing that is on every monitor these days) and it goes to this
0W
That could still be an immeasurably low current. But it's as good as ZERO.
Hard off makes no difference, unless your a douchebag ecomentalist.
Not sure what the issue was :) Chris is sorting it out and will no doubt let me know.
All I know is that there was a 2V power draw when the car was turned off. When we pulled the fuse for the GPS/Stero/LCD screen the draw disappeared. Power drain was killing my battery.
You need better equipment Dave (that's what she said)
Yeah but I CBF setting it up.
I just happened to have a Class 0.2 meter on the bench this morning, exactely the same meter that power stations use, things just dont get any more accurate. Only way to make that more accurate would be to use a really small CT and wrap the wire through multiple times.
I'd be interested to see how much a tv uses on standby...
varies wildly. Our Panasonic Plasma is meant to use .4 watts, it was actually using 22 and around 250 on average when going. A friends Samsung LED was using 178 watts and averaging around 220 when running! Needless to say it get turned off at the wall now.
We recently unplugged our bar fridge, changed some light bulbs, started turning the TV and computer and surround sound ect off at the wall and set the hot water system a bit lower and our power bill went down from around $600 per quarter to about $250. Anything with a transformer will be leaking power so switch those suckers off at the wall and save money!
thanks again for the hospitalities last night guys :thumbsup:, was a nice drive back too. heading out past the towong cemetary and up No. 5 beats the hell out of driving up the main road and down the ICB, milton road etc.
and wholy crap 600 dollar power bill?? geebus that sounds a bit painful. and a good effort to knock it down to 250's
Hey guys
How was ice-cream :D ?
Thinking about taking my car back to the mechanic to check out this sound which wasn't there before 100km service, and now it is. But before I do, thought I'd make sure I'm not just being a picky bastard and see if you guys think this is acceptable/normal.
http://mezmamedia.co...kyline_sound_1/
Edit: need to wait a good 10 or 15 seconds around there.
Edited by wilorichie
Morning Mangs,
TFIF.
Welcome! Thanks for coming.
Yeah thats the way I go.
Hey guys
Ikes Cream was good!
Will listen to your noise at home, if I remember :P
Hey guys
Sounds like it has something to do with timing belt/pulley area. mine has a sound like rubbing under 2000tpm from cam cover but it isnt rubbing. been there for 18months lol
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
