how much killer wasps does a supercharged bug motor make?
It varies a lot. Depends on how much you change the compression & timing and what charger/inlet/exhaust etc. Seen a couple close to the 150HP mark though.
Edited by Isola
All of which (especially the jetski) are water cooled? :P
arhhh yes, i now see your point... very true...
although im not sure about the Lexus, when you pop the hood all i see is a massive plastic cover...
so who knows whats going on under there, probably a big Japanese mouse on a wheel...?
also, you didn't tell me you were paying :P
also, there are laws that prevent that engine fitting.
Now you're just getting carried away :P
slight difference in air temperature/volume/density that cools that one :P
its a 41L just a lazy 2500 cubes lol
that will fit yeah?
That's bigger than the car!
The combined bore sizes are bigger than the length of the car ffs!
So? The point is that 150HP is not enough. And being air cooled is no excuse :P
Isn't that the one that caused most of the b29's to crash and explode in flames?
Probably. They should have used a Merlin.
It's plenty enough for a car and engine that size.
You wanna buy me a Porsche engine and pay for the conversion and mod plating, be my guest. Otherwise, direct bolt in FTW :P
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
    • Oh man... I've been here, that's for sure. I love my ugly but still functional headlights that can never come apart again.
