funkymonkey
As expected, didn't even hear them :(
A warranty claim just came over my desk though:
Complaint: Vehicle getting stuck in park
Cause: Buying an auto Wiring problem to shift lock release
Correction: Repaired wiring in circuit.
lolfarkin
Work over, and Marisa has just made plans with another friend of hers who is thinking of having a baby, so she's coming over to help with the babies and spend the night to see what night feeds are like
Boo Yaa, getting on it tonight
laps of happiness were good, plenty of open track :)
smity!!!! video!!:thumbsup:
Yeah, been playing cricket all day, will try and get something up tonight.
My CONSULT logger f**ked up so I'll only have GPS data to overlay :(
Did you like my demonstration of epic clutch slip as I went past you? It is completely gone - I couldn't get power down anywhere, in any gear, at any revs :(. Was pretty much limited to 20% throttle.
Had fun following you for a while though, and was still able to catch the pack when I opened up some clear air earlier on :)
New clutch time!
Not having much luck with wheels/tyres either. The front left on my track wheels is losing pressure again as well.
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
