Nissan is 114.3
the only one you will be able to manage is the last option, and it will almost certainly have to be custom.
The only way you can change from 4 to 5 is to keep the PCD the same (e.g. 4x114.3 to 5x114.3, which I think you can get without going custom).
If you want to change the PCD, you need to keep the number of studs the same.
Sonofabitch... so I'd need one of these http://www.vollks.com.au/index.php?main_page=product_info&cPath=192_210&products_id=3149 to change the number of studs, then another adapter to go from 5 x 130 to 5 x 114.3 ?
...SD spec spacer thickness by the time it's done :(
Also dodgy as f*ck...
Guy on the 31 club did it, 4-5 stud converters and then 5x114.3 to 5x120 or something. So not cool. Funniest thing is he bought the wheels brand new, and they were available in a perfect offset and stud pattern so that he wouldn't have needed ANY spacers. He just ordered completely the wrong thing. :P
nah, if your talking VW which it seems. go see Sherman conversions on the gold coast, he can sort you out with any stud pattern you like, drilled off fresh rotors or drums (not so sure on the drums)
this way you can avoid pushing your offset out further than it already is (which in a beetle is already way to far standard :angry:)
my brothers Bug has a set of commo pursuities on it.....:whistling: but he got his as a kit from the states, all wheel disk brakes and all that shiney new car jazz, in the stud pattern of his choice.
Porsche is also more expensive, as the studs are apparently entirely different to any other car and cost a small fortune.
*and dropped spindles are the way :worship:
Ooooo, now this sounds promising. So does that mean I can get away without a hub conversion? I'd like to put newer VW rims on an older one, so getting it to 5x100 would be the one I'm most keen on.
Have been looking at drop spindles, but they look pretty costly :(
have to be custom made from 2 sets of standard spindles.
So not sure of the exact price but you've got to find a second set of spindles, and then pay for the custom job. So not cheap.
gaids :(
spindles check out the whole web site man...silly cheap prices. whole disc brake + spindle kits for less than 500 bucks........seems a bit too cheap
cheaper than chips apparently, only just found this site. never knew it existed before.
as for the Beetle 5-4 stud, not sure how that goes for just swapping rotors. normally this is only a by-product of upgrading your brakes on an old one. and all disc brake bugs are 4 stud. so discs are def the way to go as it will prob only cost a little more, Sherman will be able to help you either way. give him a call, he'll be able to sort you out.
I need drop spindles for the Alfa. Also expensive :(
My brother has his old alfa sitting around.....been ignored since he did the head gasket in it (again) and got the liner. not sure what it is, ill ask him
Been perusing Vollks for the past few days. Some cool stuff there! Already looking at interior bits and pieces, because I bet that will be needed.
Pretty much set on a super, as I think I've hooked myself on that blower idea :wub: so discs will already be the go on the front. Just want more choice for wheels.
ewwww super :sick:, but yay for discs. yeah man, with the super you should just be able to get new rotors and drums drilled to suit whatever you like.
supers also have coilovers on the front, not this silly torsion bar nonsense. which costs alot more to lower and fiddle with.
There's nothing wrong with supers! Especially when you want to modify a bug but don't want to hurt an older one :)
    • Outsider is where I got my dbw system and throttle body/accelerator harness’ from. Premo quality and customer service
    • Yeah - the Hitachi core is huge (long) and the core Tao uses is quite short, so the compressor housing moves backwards. But I wouldn't let that stop me. In fact, I didn't. But I imagine that the correct thing to do is to go for the latest G series on an Artec manifold. In V band. And f**k the twin scroll, because short short Artec manifold runners + easy install/removal/adjustment outweigh the small loss in spool.
    • No. You can't fit aftermarket rails onto Nissan seats. Not without way more pain than many more sensible options, anyway. FWIW, I bought some R34 seats to put into my R32, and I didn't like the look of what needed to be done to make them fit. It's not just "mod one hole", because they don't sit flat anyway. So I pissed them off and put in some Bride reps, which is a far superior outcome.
    • Would R34 GTT seats fit into R32 Gtst ? I’m aware they can technically fit with modifying 1 out of 4 holes but was wondering if they would fit without modification with some sort of aftermarket seat rail ?    I know atleast one of you gurus can help me 😅 cheers
    • So here is an interesting vid, some proper abuse.    What I realised today is the ultra flywheel might mean no adapter ring !  Have emailed them to confirm.
