Only suggestion I have s that starfish cafe we went to at jindalee but they close by 9.
could use it as a temporary for tonight until we find soething more suitable.
Noel, the interests listed under your avatar.... are you takin the piss about a certain irritating individual that sometimes comes on here, or are they really your interests?
Not sure where you're going with that Miso, If its archery then no it isnt a piss take.
I played competitive archery at the pointy end of the field for over 30 years and would still do if a shoulder injury hadnt forced me in to early retirement.
The old girl is in NSW as we speak competing in the national 3d archery title which I have high hopes for her finishing on the top step in her respective division.
A great and challenging discipline in which I was fortunate enough to win several national titles and some high finishes on the international stage as well.
Would still be there If I could.
that explains it
I just remember Ghosty had about 30 things listed in his interests for some reason, and one of those was archery.
I wasn't sure because I remember you talkning about archery, but thought I would check just in case :P
Pretty close to the other joint, sounds like a plan.
Well I'll be there around 7/7.15 for din dins anyhoos pete. rock up if you wish to join in riveting conversation about how shitty BR at chapel hill are.
that explains it
Ah the ghost man. I think he's too busy workin on his lats n pecs these days.
sounds like a plan. What options are there for eats in the vicinity?
Morning Mangs,
Let the countdown to the weekend begin
where did you guys end up last night, I was giving the unicorn her weekly run and was about to drop by then remembered that shit had been moved- oops forgot to sign Anna out
At my previous job, my boss bought a compound bow for fun and would go up to the range in albany creek to have a few shots etc.
He brought it out one friday afternoon, jesus christ those things have some power behind them. You certainly wouldn't want to be standing in front of it, especially when I'm holding it. Also didn't realise how much tension there is required to get it going.
This is exactly why we were boycotting BR last time. But you weak homos caved :down:
Sif a boycott would have any impact when the dream boats wanted us gorn anyhooos. :teehee:
So is there any suggestions for a longer term alternative that is open late on Thursday nights and has ample parking?
The Blondes at your workplace?
What events took place to spark the eviction?
Last time I was there it was 5 or 6 of us standing around consuming assorted iced products and I believe someone had KFC.
Edited by hylian
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
