Don't know if you guys have checked out Davie's shots on facebook yet but I had a good laugh looking at them and finding a shot of what appears to be MRR33's (aka streetfame) 33 pissing out coolant all over the carpark out at pick and pay
PWND
Edited by PWND
streetwho????
oh yer the bloke that lost to that 31 at last years cruise...
Is that the clean as fark midnight purple 33 gtst? Then it's all let down when you look at the white interior, the gauges in the dash on the passenger side (I still don't get why they put them here) with the slushbox?
RE: Thursday - I usually go to Hanaichi at chermside, that's probably not what you were aiming for though.
Lotus Notes isn't opening for me today........ no work to do.. woo!
Edited by hylian
I doubt many cafe go-ers would want to see my dirty BA sitting in their cafe. I would need a fair decent anchor point anyway!
Good place for me to sell it though:
2 owners, roof lining in average condition, miss fire when floggin' it, 4 doors fits more wh0res.
2xbox controllers, 1 fishtank, r33 viscous diff and $500 cash my way.
EDIT: I don't actually want any of the above in trade for my car, if you do want to buy it, you're looking 10k for an 05 BA MKII XR6, prem sound, needs rooflining done, new tires and coilpacks. (although I plan on doing all this myself in a week or so anyway)
Edited by hylian
Most likely leaking through the valve and several shoddily applied repair patches
Re: Thursday.
I have no idea.
Indro Maccas,
Taringa HJs,
Toowong Car Park Dealie,
Mt Cootha?
And I'm out of ideas. Could try Kelvin Grove uni there is a nandos, subway etc around there.
Wouldn't mind trying this towoong carpark dealio, but i guess getting everyone to find the place could be an issue. meet somewhere else and drive there at 8 or something?
Yeah Kenmore is not bad either. I'd say go for the Nando's there rather than the maccas as there are more seats n stuff.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
