funkymonkey
Spent a few hours pulling all of the interior out of a s3 ti today to put into the wagon. Only problem I can see is that the won't work with a ca20 and that the rear and front light plugs etc won't work on the pintara. Conections for the lights are east to change.. I think. And for the other problem I'm pretty sure I need to invest in a 30 for it.
Week has been super unproductive.
Kids been sleeping crap so motivation is at an all time low.
car has been sitting in the driveway for the last four weeks undriven, as it doesn't have a bonnet.
On the upside, my black ops kill to death ratio has been steadily improving over the past four weeks
In a great end to the year my gearbox may be going the way of the dodo :(
After a little spirited driving this arfternoon it suddenly decided to put its self into "safe mode" or whatever it's called. 3rd gear only and the A/T light was up on the dash. Pulled over quickly, turned her off and let her sit for a little while. Struggled slightly when starting her back up, bit of a lurch and was back idleing like normal. Was a bit cautious on the way home.
Major sadface, can't afford an expensive mechanical issue, I wanted to buy an S13 in a couple of months.
Happy New Year Everyone!
Time to get our Go Kart date sorted. I can do after 1030am every Saturday and after 1130 on Sunday. If those time are fine, I'll call and secure a slot for us this coming week.
just watched Martins wrap up video, I really need to get my richness issue sorted out! At least I can accelerate under the cover of my smoke screen though, stealthy.
yep you have a bit of a smoke screen happening there :)
bunnings = win. looks like they have started selling pallet racking. bought two big racks and a lot of shelves. now my messy garage is now tidy :)
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
