What type are they Miso? And what bonnet?
didn't see this post
aerocatch ones, linky, and into a gtr bonnet
Edited by PWND
Morning Mangs,
Internets have been boned at work this morning :(. Not fun.
BF3 upgrade package was (eventually) a great success. Sh*t is fast.
@Pete: Did back to back benchmarks on single drives and RAID0 and didn't notice much improvement with the RAID, so I kept them as two single drives and one will be the windows drive and the other for pagefile/games/software/etc.
So, Buranda it is on Thursday? Centro Buranda is it?
Any time I have said I WOULD come I have been there...My might record is not as good lol
I'm trying to remember how often you actually turned up to stones corner... :P
PS when the hell is our next cricket game, I have totally lost track.
22nd. I reckon we should hit the nets this weekend.
When you have done yours and are a master at it, you can put some on the alfa for me ;):D
So what, your only getting 200mb/s transfer speeds. How horrible :P
I am trying to remember is I ever said I was actually going to come? :P
Yeah nets this weekend would be good
Yeah I know, it's dreadful! BF3 map load times have gone from 3-4 minutes to 10-20s. And Windows, etc all load lightning fast as well :D
Just thought you'd like to know you were proven right regarding RAID :thumbsup:
I'm pretty sure you did ;)
Cruise sunday, so Saturday?
I can do saturday. can you send the email? I am out of the office and have not.figured it out from my phone lol
Will do. Have you had a change of heart regarding indoor tonight? :)
Sorry mate. lots to do and Anna is freaking out. should stick around and help oit
Seeing as you lads are mentioning BF3, I just brought my new lappy - Clevo Horize with a 6990 gpu, I7 2820, 8GB of RAM and a 500gb Seagate Momentus Hybrid drive.
No more problems with crappy map load times after you have loaded them a couple of times it loads them like lightning (the 4gb ssd drive on the Hdd will cache commonly used files applications use.
Ultra graphics on a full HD screen in a lappy makes gaming on the run awesome.
I hope those hybrid drives catch on. They're a good idea but only 4gb of SSD space just isn't quite enough. But if noone buys them noone will make one with more SSD size. Chicken and egg.
Mang, add me on Battlelog or whatever it is. Smity42.
Yeah mine was literally taking over five minutes to load the bigger maps. With the SSD it is seconds. It's astonishing.
nice what did that cost you????
add Ralf to your Origin while your all at it. Mumslayer...i think
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
