agreed, love those events in a game...but in IRL, i dont think i'd have the balls to even try.
BOZ! did you get your car back yet?
and a simple spark plug question for one and all. the iridiums that are in my car are heat 6 gap 1.1. should i stick with this with the new plugs (prob just coppers)
or go down to a 0.8 gap? my 5000rpm+ stutter is getting worse :( just wondering if it might just be the gap?....or the distance driven with them in.
I'd take water over flipping and fire any day of the week. Unless you have a VERY difficult car to get out of I'd say your chances of survival are higher in a splashdown, more time to react. Both are terrifying situations however.
Upside down, on fire and in the water however...
The one that always has me on edge even watching are the crazy cliff drops on the outside of many European Tarmac rally's or events like Pikes Peak. That's a damn long way to fall with nothing but skill stopping you going over.
and on that topic. i just downloaded a Jeremy Clarkson DVD collection. the first one is Motorsport Mayhem from '99 and i just watched a corolla drive straight down a cliff and end up upside down in water.
No car yet but it must be actually done (or so close it doesn't matter) as Just Car contacted me to pay the excess. Once the payment clears I'm hoping she'll be back in my hands :)
On the topic of spark plugs, I gapped down to 0.8mm on my last spark plug change (about 10,000km ago, they are due for another change soon) and it helped no end. Once I get my baby back she'll be getting an oil change and new plugs straight up, i actually have a bit of space to work on her now, just need to actually buy some axel stands and a jack :P
How much boost you running bodo?
just stock boost, with the low boost bypass job.
copper sparkplugs, smaller gaps, and replace them while doing oil change. costs less than fancy plugs and does the job just fine.
yeah im gonna go coppers, the iridiums do save alot of time as the plugs aren't a 5 min job with standard pipe work, and 5000km was every second month the last few years (thankfully that is no more)
the 6 heat range should be fine then i assume?
Anybody aware of any cheap standard skyline seats for sale? Need some till my fixed back gets here
i got a set of 34 seats cheap at a place called the Panel house in slacks creek, they had all types and sizes there for relatively cheap. my clean pair of 34 seats only cost me about $150
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
