they'll get a sponsor no problem, the team is a good team always up the pointy end so good advertising for the right price.
When Betta Electrical went belly up it only took a couple weeks to get vodafailure onboard, my guess is they already knew so won't be short sponsorship next season
so where would you guys suggest buying coilpacks from?
best ive found so far for a series 2 is $440 del for yellow jackets.
and splitfires $575 del.
for the extra 135...should i just go splitfires?
well nothing that ive heard...just splitfires are alot more tried and tested and proven, i guess only because they've been around longer.
having said that...i do have a mixed opinion of splitfire anyways. my bug has splitfire plugs (about8 yrs old now...and the only performance thing available at the time), which work great. but my splitfire tacho...also in the bug.....leaves alot to be desired (VDO should have been my choice here)
lol.
for peace of mind?.... :domokun:
I have ordered the yellow jackets from performance-wise. $410 express posted! should have them in for next weekends happyness of lappyness.
just spent 2 hours fitting in this "reco'd" brake master cylinder, bled it up only to find when i tested it the thing still leaks out the rear seal
unless you have no other choice....never reco a brake cylinder. (is what ive learnt over time) and the kits are generally almost as much as the whole new part. :)
yellow jackets arrived today. epic delivery time from Performance-Wise!!
mmm poast.
day after origin...i wasnt heading out tonight.
on a related topic, coil packs are in in record time! 1hour between turning the car off when i got home, to firing it up for a test run. :woot: (engines are quite warm for a while after turning the car off...)
they work great, cant wait to hit lakeside on Sunday
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
