Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
I have a tramp stamp for her. When do you want it ?
Wickedphatradtotallysiiiiiiiiiikkkkkkk
Next baskins meet I come to? Probably another 2 weeks?
What model? I used to have a KH, it was wikkidsik
KE....... and yes its wikkidsik
Tristans bday today? Happy B'day sexeh emo. Baskins this week for birthday reacharounds?
My scrying orb (facebook) tells me it's on Fryyyyyyyyday
baller
Wait til I lower that mofo! and get some massive 15" rims :(
2 weeks ?!?!??!!?!?!?! ?
That's what he said.
soft
That's what she said.
but ok
Neither of them said that
Edited by mosquitocoils
Gents
I have a ford laser in my driveway. Her name is Kelly. Be nice.
TRD Laser :( wicked
So I read this...
Dammit! really wanted to go to the baskins meet but now can since i have to get my car towed back home and take the engine out to check the rear main seal and the clutch, the reckon with the clutch the pivot ball is too long for the os Giken twinplate i have in there, does anyone know if there are different sizes of pivot ball for the gear box's? i thought they were all the same sizes? but the thrust bearing carrier is really tight. the box im using is the rb25det from a r33?? are the 32gtr pivot balls in their gear boxs smaller does ayone know?
but all I really got out of it was:
so... I don't know the answer to your question, but I do have half bar.
So Thursday reacharounds?
Only if i get them, being the 22nd is my bday
You actually have to SHOW UP to get the reacharound, Josh :P
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
