Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
BOV sounds like success? Looking forward to epic flutters/skeeet! on Thursday
seems to be! I need to get it to the right level though, so in the presence of Mr Plod, I can shift gears around 4k and not have it scream.
which variety of circlip John? I've probably got the tool to do it
one of these
internal kinda ones
Yeah it's like $10 from supercrap for a pair of circlip pliers that comes with 4 different fittings or whatever... I got mine purely for my SSQ when it was on hahahaha
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :)
yeap, i've got the tool for that one
Hammer? I've always used long nosed pliers for them. Should probably get some circlip pliers though would be handy
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :blink:
Lol good idea.
Can do that if your long nose pliers are pointy enough. Can also get em with a couple of screwdrivers, but its a bit more effort
Need to keep my monies to buy grog for services rendered though. I got some sockets and a ratchet the other day, and a window scraper. Decided to build the tools up a little at a time. As long as Jason doesn't come over and break them all will be good :P
I asked you if they were HULK rated
fiber :down:
Tried a couple of allen keys with no glory... it's tighter than a jewish girl who was made to sign a prenup
any sharp implement is fine really
fiber :down:
Silly John he should of known not to get you mad :P
That's tight.
Morning mangs
Sup everyone... picked up a Gregorys service manual for the TRD off ebay last night for $20 :P
Drum brakes eat your fkn heart out.
Yes....... I = noob.
What's goin on today?
Doin' your mom
I need to get one of them for the alfa, but they are like $60 :down:.
Alfa factory manuals I have, but they are f*cking useless
Doin' yo mom, do-doin' yo mommm
Doin' your mom, yes yours, I saw her at the walmart, pickin out your drawers
Yeah they're expensive brand new. But sooo damn handy hey.
I NEVER look at my 31 one any more, but it sure was handy back in the day :down:. I refer to the XF one occasionally. The alfa one apparently has info on how to adjust camber etc, which I can't find in the factory manuals I have :P.
Plus most gregories/haynes have much better pics of things than these alfa factory manuals have.
Service manuals ftw.
Doin' your mom
I need to get one of them for the alfa, but they are like $60 :down: .
Buy one then scan it and sell it as an ebook on ebay/alfa forums. recoup your $60. Win.
I NEVER look at my 31 one any more, but it sure was handy back in the day :banana: . I refer to the XF one occasionally. The alfa one apparently has info on how to adjust camber etc, which I can't find in the factory manuals I have :) .
I should get one for the 32 tbh but I'll just end up winging it instead. I have the factory manuals but they aren't that helpful.
I concur.
I also has Autotune. Bitches.
Autotune your mum.
nissan factory manuals sh*t all over these alfa ones
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
