Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
oh, and will seam weld from the a pillars to all the front suspension mount points. Theres just no practical way to get enough cage bars through there :3some:
Actually it looks like it may be possibly, by going inside the front guards (which are welded on :)). I might look at how to get those suckers off...
Whats there now?
Are you happy with the tune you got from STZ mang? They are a haltech premium rep or something... (gonna run a PS2000 on the alfa)
there is nothing there - its 100% bare.. hence why i asked
f**k moving all those cars - would have taken ages, would have been a fun night however lol
mate STZ were amazing, car runs so sexy - marty and mic said if there are any dramas just pop in and they'll have a look
defs recommend them bro!
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :3some:)
cant remember what turbo/power figure, but its definitely a very "tame" set up (not like high-octane racing for example)
give them a buzz fo-sho
I say dan buys it and sets up a workshop there :3some:
their s13 runs a 60.2 on QR Sprint track - go figure, that thing has the haltech in it (and an SR :))
Cool as, they are about 2 minutes from my work :down:
...Will be a while till I need a tuner though ;), just doing my research...
Cool as, they are about 2 minutes from my work ;)
...Will be a while till I need a tuner though :) , just doing my research...
dude lets buy it - hoists win!
but yes STZ ftw! should go down and chat to them, i was there for ages just chilling - great guys
I say we all chip in and make it an Apocalypse fortress :3some:
Keen for apocalypse fortress/ somewhere with a hoist. but John needs a job first :)
Martin i can chase down the original workshop manuals for the GTV.
Phantom has relocated over near moss street from memory, i wanted to take the RX7........
If someone wants to front the cash i'll setup a workshop there and mini skid track.
Also, concrete carparks in the wet are too easy
I have them on that disc. They are sh*thouse :thumbsup:
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory :(. Looks like nothing adjustable on the rear :)
Build your own damn fort then.
Fine maybe I will...
Workshop+skid track = win.
Morning Mangs
Epic fog is epic :thumbsup:
Morning mang no fog here but it's pretty quiet on the way to work these days.
Morning to you fine gents
The fog's actually gotten worse since 6am...... go figure, usually it works the other way
Night all.
Is it just me or are those roll over ads at the top a pain in the rectal area? :):thumbsup:
I have them on that disc. They are sh*thouse :(
I did find the bit for adjusting suspension though. Height, Camber, Castor, Toe all adjustable on the front from factory ;) . Looks like nothing adjustable on the rear :D
That's awesome. How much adjustability do you have though?
Could be that deadly fog that turns people inside out. I here it has been getting around again.
Night all.
So true. But they have to make money somehow.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
