Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
yeah, I'd remove that split pin or it could get pretty messy.
bring the two "split ends" together with screwdriver/pliers whatever (so it's straight again), then pull it out from the non split end
One of us is tripping balls, because I see no split pin in that photo :S
Dumb question - how does it remove? Pry the squashed bit up with a screw driver.... then what?
Ravi, it look to me like that squashed bit is the equivalent of the split pin, ie it stops the nut spinning. Once you pry it up with a screwdriver so that it will no longer interfere with the nut spinning, you should be able to take the nut off in the usual fashion.
Unless of course there IS a split pin, then you'll need to remove that as well.
just checking in
Touge?
1
2
3
BINGO
That's what she said
Pfft. You would.
Pfft. You would.
Morning Mang. And other Mangs. And Colin.
Keen?
Always
I wish
Gonna go down to the TRD garage and check the status of said split pin right now.
Ahahahaha 'and colin'.
Morning.
And purged for 8?
Split pin is split. If that's what it is. Stuck on there harder than.... well..... you get the idea
Always
I wish
Morning.
Quiet you :D
Waxing.
You?
Fapping obviously
first day back at work today, after 6 weeks off.
so so ghey
That has to suck balls.
I look hot in my little v neck sweater today
Pics or GTFO
I stopped eating for 5days
Pfft only 5 days..
And purged for 8?
Ahh, I think I see what may be a split pin now. Hard to tell from that pic. Demand MOAR pics, high quality.
Yeah I don't think it is a split pin as such more of squashed something over the bolt. Flat blade screw driver or some long nosed pliers would be my guess and try to pry it apart. If nothing else works set it on fire.
Fire solves all, I hear.
Screwdriver didn't work. Just bent the ducker lol. Will try needlenose pliers this arvo I guess. Sigh.
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
