Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Yep I have the manwell for it. I downloaded it from the website. I went to the off setting and it didn't seem to do anything. It was still giving me infinity boost.
F*ck, that's not good :ermm:.
Bring the manwell tonight, saves me having to print it.
Lol @ NASA
Voyager 2: *Gibberish*
NASA dude 1: Hmmm, voyager 2 seems to be broken
NASA dude 2: Have you tried turning it off and on again?
NASA dude 1: Naah, we'd better figure out whats going on first
several days later...
NASA dude 1: Yeah I figured it out, theres a bit-flipped in memory
NASA dude 2: OK, how do we fix that then?
NASA dude 1: Lets try turning it off and on again...
ATTN: Phil, Misohorny, John, Dan
Work out a day that works for everyone to fix Jasons AVCR and do Miso's brakes. Dan will need his brake bleeder. I can't do it this weekend though.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :ermm:
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :D
Trying to clean up scanned alfa wiring diagrams to print. HOPEFULLY they are the right ones :S
Cool, sounds like it will be a good turn out tonight. Thristian, you coming?
Sounds expensive. So whats doing mangs? I'm typing meeting minutes :(
Very expensive. You can only import them.
I am easy. Just let me know and i shall be there. Can work it out tonight at baskins. No longer jet lagged, so won't sleep through it. :P
Anytime is good for me ( if i can afford to drive there :D ) I'm on day shift this week and next and have this weekend and next one off. :ermm:
Anytime is good for me ( if i can afford to drive there ;) ) I'm on day shift this week and next and have this weekend and next one off. :down:
I think tonight we will just bypass the AVCR and pipe the wastegate actuator directly to a boost source. This should put you back to stock boost (stock LOW boost probably) which will get you by (and hopefully fix your fuel economy) untill we can sort it out. Hopefully next weekend will work for everyone.
If it still boosts it's t*ts off, or you still get bad fuel economy, then you have other problems.
I'm not 100% sure how the AVCR can be ruining your fuel economy so much, if anything I would have thought it would make it better as you'd be trying to drive off boost all the time...
Edited by Smity42
+1
o2 sensor? when was that last replaced?
+1
I've only had shitty fuel economy since the avcr. But it is getting worse and worse. How much is a o2 sensor ?
Jason... did you let you car hang out with mine again? I started her up this morning and she was all lumpy and shaking and carrying on, and drives like a bucket of shit :down:
Just letting it cool down now so I can see if I can work out wtf is going on with it ;)
like $100ish i think man
i have a spare good one you could try - if they fit (its an sr one)? idk if they do
was the avcr new? who installed the avcr? i'd give them a bell maybe they f**ked up? (or was it you that fitted it :down:) jks jks
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
